Help.
Mumpka
I recently got an SSD and installed windows 7 on it, and for some reason any game I try to launch crashes immediately. I got this error when trying to launch KSP: "The game has crashed. The crash report folder named "blablabla" next to the game executable. It would be great if you'd send it to the developer of the game!"
I get the same thing when I try to launch Rust. It's not just unity though, I can't launch DayZ either.
Specs, make of SSD, drivers up to date? etc.... In order to help people need to know more about your machine.
and we will live such tragedy in perpetuity.
did you reinstall those games?
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
I literally just installed them and I'm having these issues.
all newest drivers installed?
idk how do I check?
idk how do I check?
if you didn't install the drivers
then they aren't done
you need to get all the newest drivers from the various chipset manufacturers
idk how do I check?
Open device manager. Every yellow triangle you see is missing driver.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
