hey guys ive been wanting to build a custom pc for a while but i have never been able to decide what parts i wanted/needed. i have made a parts list of what i think is good for $780. i would like some suggestions on what could make this build better. thanks!
http://ca.pcpartpicker.com/user/Lolbroccoli/saved/2aK5
Current PC: Chimera, Because AMD and Nvidia belong together
| CPU: AMD FX-6300 | Cooler: CM Hyper 212 EVO | Mobo: Gigabyte GA-970A-UD3P | RAM: G.Skill Sniper 8GB (2x4GB) DDR3-1866 | Storage: A-Data Premier Pro SP600 256 GB SSD, 2x Seagate 1TB 7200RPM HDD | GPU: EVGA GeForce GTX 750ti 2GB SC | Case: CM N600 | PSU: Corsair CX 600W(Overkill but I was originaly planning for a 970) | Moniter: BenQ GL2460HM 60Hz 24" |
Left five, Don't cut, Be brave.
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/
i would change to 4670k but the it seems liek a budget build so i would recommend FX8350
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605686
pick a 500 watt corsair psu to and, change that solid state drve the a kingstin or a samsung basic 830
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605696
Get atleast a 500W PSU, Get the Samsung 840 insted of that SSD, and get the COrsair Vengeance Ram, even 16 gigs if you have the money.
PC Specs:  2x GTX 550 ti in SLI - Intel i7 2600k @ 3.4Ghz - Thermaltake Overseer Case - 8 GB Corsair Vengeance Ram - 1TB Harddrive - 500 Watt PSU that came with my old prebuilt pc lawl -  ASUS P8P67 EVO
Peripherals:  Razer Deathadder Black Edition - Razer Arctosa Keyboard - Logitech G53 Headset
Cool song of the day: Chief Keef - Round da Rosey    Changed my profile pic again...                                        Mountain Dew is good. So are video games and music. Oh and unicorns.
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605713
The 4570 is not overclockable. You want 4570k.
Ryzen 5 1500x, Noctua NH-L9x65 SE-AM4, GA-AB350N, 16GB 1600Mhz, EVGA GTX 970, 250GB Samsung 960 Evo, 120GB Samsung 840 Evo, 1TB WD Green & 2TB Seagate Barracuda. 650w OCZ ZX & Cooler Master Elite 130. Acer CB241HQK 4K, LG IPS234V-PN 1080p, Ducky Zero Shine All Blue/Anne Pro Brown/SteelSeries Apex Pro & Razer Naga 2014
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605726
Two recommendations:
1.  Get a better PSU.  You can get a CX600 for pretty cheap.
2.  Get a 7950 instead of a 660TI.
The 7950 is a MUCH BETTER card and it's actually cheaper right now.  You can get a great Sapphire Dual-X 7950 for $219 after rebate. Not to mention it comes with 3 free games starting today.
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605730
First get 500/550 W psu. Then I would get a 60 gb ssd and use it for caching, if not you will fill up your 120gb with the os and 3 games and office and 2 more programs lol.
Then, with the money I save from the ssd, I would upgrade the gpu to a gtx 770
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605736
so far i've added the i5 4670k and a corsair cx500
woahh need a better psu man, that thing will be right on the edge if you OC at all
so far i've added the i5 4670k and a corsair cx500 psu, thanks for the feed back. i dont mind going a bit over $800
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605747
Yep, that is a good option too. And it's cheaper than the 760 xd
NOTICE: someone check the ram memory compatibility issue. I'm not sure myself
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605763
added a XFX 7950. it was the only one that cost 219 after rebate
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605791
Wont he need a Z87 not an H87 chipset on his motherboard for real overclocking?
This was me going off of the fact he has an after market heatsink.
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605813
Haven't used XFX myself, but I know they have a lifetime warranty on their GPU's so you can't go wrong there!  Best of luck!
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605814
i had to get rid of the ssd all together to stay within the original budget. i don't mind it being slower with just a hard drive because it will be faster than what i'm using now
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605819
Unbalanced system. Get this instead :
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($119.99 @ Newegg)
CPU Cooler:  Cooler Master Seidon 120XL 86.2 CFM Liquid CPU Cooler  ($39.99 @ Newegg)
Motherboard:  ASRock 970 EXTREME4 ATX AM3+ Motherboard  ($98.98 @ Outlet PC)
Memory:  Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($56.99 @ Newegg)
Storage:  Samsung 840 Series 120GB 2.5" Solid State Disk  ($90.99 @ Amazon)
Video Card:  MSI Radeon HD 7950 3GB Video Card  ($239.99 @ Newegg)
Total: $784.90
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-08-14 17:04 EDT-0400)
You can also wait till september and get a 9950 ( it'll be 350-420 dollars or so so you have some time to save-up i guess, but the performance will be on par with the nvidia GTX 780)
6300 is MORE THAN ENOUGH for gaming. Also 750 Watt is overkill , but i saw it for the same as the 500 watt so why not :P
Interested in Business and Technology
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605842
Total: $784.90
the thing is that in canada that costs like $900
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605900
:o You are shopping from canada i didn't know that well i now used the canadian pcpartpicker:
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($119.99 @ NCIX)
CPU Cooler:  Cooler Master Seidon 120M 86.2 CFM Liquid CPU Cooler  ($49.88 @ Canada Computers)
Motherboard:  MSI 970A-G43 ATX AM3+ Motherboard  ($75.50 @ Vuugo)
Storage:  Kingston SSDNow V200 Series 128GB 2.5" Solid State Disk  ($85.48 @ Newegg Canada)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($64.99 @ Amazon Canada)
Video Card:  MSI Radeon HD 7950 3GB Video Card  ($259.99 @ NCIX)
Case:  NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($62.79 @ Newegg Canada)
Power Supply:  Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($54.99 @ Canada Computers)
Total: $788.60
(Generated by PCPartPicker 2013-08-14 17:27 EDT-0400)
WOW that memory is cheap at NCIX! I don't know if it's a glitch or something but if it isn't get that fast so you can use it with whatever you are going to chose!
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-605983
Total: $788.60
Also if you can replace the fan of the seidon cooler , replace it with : http://www.memoryexpress.com/Products/MX37464
Or Scythe Gentle typhoon ,  Noiseblocker fans if you can find em
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-606189
Just change the i5 to the non-Unlocked version, cause your going with the H87 chipset, is the same as the Z87 but don't have the overclock feature.
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-606648
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-607833
Don't get XFX, they are not a great company to buy now, get a saphire, HIS, or MSI.
Why is it not a good time to buy from XFX?
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-608278
http://ca.pcpartpicker.com/p/1scIh
Note that the price includes 2 sets of ram, remove the one you don't want, I just though that if the ram at NCIX is really that cheap then you should definitely swipe those.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/45987-780-first-pc-gaming-build/#findComment-609414
