Custom curve CPU fan?
Go to solution Solved by NeatSquidYT,
BIOS
Hi everyone,
Does any of you know whether it is possible to create a custom curve for the CPU fan? (And how)
I'm running a xeon 1231v3 at 40C, and I would like it to be less noisy (I don't mind slightly higher temps).
The cooler is a CM Hyper 212+.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/458501-custom-curve-cpu-fan/
What motherboard are you using? I know some ASUS motherboards have the capebility to set your own fan curve using their software, which I forget the name of.
I have the MSI z97s SLI krait edition.
I know, I know. I had a g3258 before and the motherboard just looks sexy as hell (IMO) which is nice if you have a windowed case which sits on your desk (which I do).
My System:
https://linustechtips.com/topic/458501-custom-curve-cpu-fan/#findComment-6152855
SpeedFan http://i.imgur.com/7apOq4r.png + if u have more fans connected on ur motherboard and they are PWM (the slots aswell) you can control those too
CPU : i5 4670k @ 4.2Ghz | Cooler : NH-D14 | GPU : Sapphire Radeon HD 7870 [OC] | MB : Asus Z87-Pro | RAM : A-DATA 8GB 1600Mhz CL9 XPG Black | SSD : 850Evo 250GB
https://linustechtips.com/topic/458501-custom-curve-cpu-fan/#findComment-6153056
