First post on LTT, so please be gentle (I use r/buildapc). I have never built a computer before, and I'm planning a pc build right now. I was wondering whether an i5-4460 processor would hold up to an R9 390, and 8gb of DDR3 RAM. Would I be able to run games like Planetside 2 at ultra/60fps? I'm looking for great gaming performance, and the ability to record and edit footage from games.
https://linustechtips.com/topic/458437-i5-4460-advice/
yes that is an amazing set up and would be great for almost any game at 1080p and 1440p
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151806
it's fine for any GPU
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151810
Sounds like a great combo to me :)
Other systems I've built:
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151816
Definitely, might want to step up to the 4590 though, since it has a higher clock for like $10 more.
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151821
100-200MHz aren't worth - no difference - mine was on sale for cheaper xD
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151828
Forgot to say I'll be doing 1080p gaming.
Yes it would be great, however for record and editing footage i would recommend a i7 4790k, but thats if your doing a good amount of it.  The i5 non-k will be fine though.
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151832
i7s are overhyped - a Xeon is better than an i7 for work
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151843
It is, but still a good cpu, i myself am looking at getting a i5 6600k.
4690K will be about 70$ cheaper (even more if you re-use RAM) and will be only 9% slower
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151874
Great. I was pretty sure it would work, but an employee at memory express told be I wouldn't be able to do gaming with any less than an i7. I guess he assumed I was clueless, and tried to make me buy more.
Employees at stores are idiots with a big mouth - avoid them.
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151876
Completely, but my memory express has a great track record, and helped me figure out my first upgrade ever, so I thought I might ask them. I'll definitely come here for future advice, especially since you don't seem to have a bunch of rules about what kind of questions I can ask.
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151918
I was also wondering if someone could recommend a motherboard that can handle these parts for <$77USD/$100CAD. By the way thank you all so much for the advice! This forum is way friendlier than r/buildapc, plus you all responded crazy fast.
Slightly over-budget, but these two are good:
https://ca.pcpartpicker.com/part/asrock-motherboard-h97pro4
https://ca.pcpartpicker.com/part/msi-motherboard-h97pcmate
(I assume you're from Canada, seeing as you put 100 CAD as your budget :))
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151941
Yeah, I am. I only realized like 3 days ago that I was WAY over budget since the Canadian dollar is worth so much less than USD. Thanks for the suggestions. I have a quick question about MOBOs. The only important things about a motherboard are the compatibilities, since its the thing that connects everything else, right? I won't lose any performance by using a cheaper MOBO?
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6151984
nope - as long as you have a PCIe 3.0 x16 slot for the GPU and the right socket for the CPU it's fine :)
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6152022
Nope - as long as you have all the necessary connections a board will not affect performance in any measureable way AFAIK.
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6152086
And those MOBOs have those, right? I really know nothing about compatibilty.
Look up the specs :)
If it lists the expansion slots as having a PCIe 3.0 X16 slot then it's fine. - also check the RAM speeds for your memory and the voltages.
https://linustechtips.com/topic/458437-i5-4460-advice/#findComment-6152088
