Water Colling Questons
Solved by Mao_Zedong,
1) Yes, but not by very much. It is more cost effective to buy higher end other components if they are available.
2) You should basically never go under $200 for a CPU only system. For $300 you can get a decent CPU only system. For around $600, you can get a good CPU + GPU system.
3) Not really, the biggest advantage is aesthetics.
4) No, I would try it later. You could use a CLC/AIO though.
