Help on my pc build
Focus on why your buying a certain part. Some parts cost more than something that may do the job just as well, but we also like nice things in our systems. I'll use Ram as an example. You can find ram that is as fast or faster than the Dominator, but If you like the Corsair ram and can afford it then it's up to you whether it is worth it to you. I'm sponsored by corsair and they sent me a 1200i - heck ya I like it but an AX860i would do the job for me and you for what we are doing. People started buying humongous power supplies as a status symbol, but most system don't need anything near that power level. Personally I would stick with the processor and mother board. The previous advice is good if you want to get the most bang for the buck, But it's always nice to have the current top of the line if you can afford it. Build it like you want it! We all have are own personal vision of our dream system.
