I am currently installing the SATA power cables to my Samsung 850 EVO and WD Blue 1TB HD. I am wondering if it matters which sata power connector you hook up to (there are four total, all hooked into one cable)? The drives aren't close enough to hook into connectors 1 and 2 so they are currently hooked up to 1 and 3.
| Intel i5-6600K | NZXT Kraken X61 | MSI GTX 980TI | NZXT Kraken X41 | ASUS MAXIMUS VIII Hero Corsair Vengeance DDR4-3000 16GB |
                |Samsung 850 EVO 250GB | WD Blue 1TB | EVGA SuperNova G2 850W | Fractal Design Define S |
https://linustechtips.com/topic/456047-sata-cable-connection/
It's alright.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120015
doesnt matter
just make sure the sata data cables go into the right ports
some are 3gbps, some are 6gbps, and some are not intel controllers so dont use those
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120040
Nope. Power is power, there is no difference which of the four you use.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120051
Refer to the motherboard's manual on which SATA connectors use Intel controllers.
EDIT: Ah, power cable; does not matter which connector you use in the link.
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120054
Thanks guys...
Can I run two separate SATA power cables? I have multiple SATA power ports on my EVGA PSU. This would clean up the cabling quite a bit.
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120087
You can
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120327
It'll work fine... but the real issue will be if you have OCD, drove me nuts everytime i boot to the bios and there was nothing connected to sata 0.
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120427
Hey there CC268,
Any SATA cable should work just fine and you shouldn't notice any difference in speed. Some have extra latches that make the connection to the drive or to the motherboard more secure.
The ports differ in type (SATA1 (1.5Gb/s), SATA2 (3Gb/s) and SATA3 (6Gb/s) but regular HDDs can't really saturate the speed limit of the ports so it shouldn't matter where you connect them.
Regarding the power cables, the one that comes from the PSU has several plugs and you can use a single one for all drives with no issues or impact over the performance. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6120845
Thanks guys - not sure what else to do other than to connect the SSD to the first SATA power connector and the HD to the third SATA power connector. Unfortunately with this Fractal Define S case the SSD and HD aren't right next to each other so it makes it tough.
I haven't got around to plugging in the SATA cables I will have to see how that works out.
https://linustechtips.com/topic/456047-sata-cable-connection/#findComment-6122478
