I currently have my i7 4790k running at 4.5Ghz with auto voltage. The voltage autos to 1.229v.
Is it a good idea to manually set the voltage to 1.229, then raise the multiplier? If I put the multiplier at 4.6, with the voltage on auto it will go to 1.3 which seems a bit high.
So my main question is what is the best way to test and push my CPU? I am air cooled.
Thanks!
https://linustechtips.com/topic/453959-4790k-overclocking-questions/
put the voltage to 1.3v, and increase the ratio by 1-2 and stress. if it passes after 10 minutes, repeat.
keep doing this until you get as high as it will go.
after you get it as high as it ill go without crashing, decrease voltage by .01-.03v and stress test. if it doesn't crash, repeat until it's unstable, then go up one after it crashes.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
hope this helps
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
Thanks!
I wouldn't go any higher then 4.7 on air
1.3 is perfectly normal. as long as its under 1.35 the chip wont degrade
to push your chip do a Cinebench benchmark or a stress test DO NOT USE PRIME 95 ON A HASWELL CHIP ONLY IF YOU HAVE IT ON A FIXED VOLTAGE
thanks. i thought that 1.3 was degrade life. is cinebench+aida64 good tools?
awesome thanks
awesome thanks
go for AIDA64. cinebencz is a good real world test, but doesn't really stress the cpu like aida or OCCT.
if you don't want to pay for AIDA, I use OCCT for all my overclocking. :)
Thanks!
Do 1.3v volterinos for vcore and do like 1.95v input
PEWDIEPIE DONT CROSS THAT BRIDGE
so i shouldnt leave input at auto?
