CPU temperatures and which CPU cooler should I get?
Teemo4Life
Playing cs go with the pentium g3258 3.2ghz and runs 60'. Why is it so high. Anyway to fix it
Which CPU cooler should I get?
1.Cooler Master Vortex Plus Universal Cooler
2.Cooler Master Hyper TX3 EVO CPU Cooler
Or any other CPU cooler $30 or under
Do u need to apply new thermal paste.
60 isn't high.
- CPU: Intel i7 3770 - GPU: MSI R9 390 - RAM: 16GB of DDR3 - SSD: Crucial BX100 - HDD: Seagate Barracuda 1TB -
60 is good, you don't really need a new cooler.
If you are going to get one though I recommend CM212 and you need to apply new thermal paste (comes with 212) but 60 is good.
What if I OC. It won't handle it
i use the TX3 and i like it. changed the fan on it tho.
Why. Is the stock fan good
No problem with the stock fan. i just had some better fans lying around.  ;) i use the tx3 on both of my rigs. the other one uses the stock fan.
Thoughts on it? Is it good for OC,
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
If your cpu gets to hot when you are trying to overclock it it will just dial back the overclock.
