Finished PC Help
Go to solution Solved by Tedster,
Build : http://uk.pcpartpicker.com/p/6gxcD3
I have just finished digitally building my new gaming PC online as was hoping that someone would be able to take a look at it and give me any feedback. (If there is anything I should change for if I should not go for something)
I plan on playing any games that come out that I like the look of.
Any help appreciated.
1) You don't need the Hyper 212 Evo for a locked i5, you can use the stock cooler if you want to save some quids.
2) You can probably go with a slightly cheaper motherboard if you wish.
3) I'd throw in a Samsung 850 Evo SSD - suggesting the 250GB one.
4) Please don't make the mistake of going with a case from CiT - if you want something that looks good and is cheap, look at the NZXT S340 or a Fractal Design Core series case.
https://linustechtips.com/topic/452745-finished-pc-help/
get this psu instead its cheaper and better http://uk.pcpartpicker.com/part/xfx-power-supply-p1550gts3x other then that this a good build
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/452745-finished-pc-help/#findComment-6071839
I am sure someone on here will build you a lot better PC for about the £800 mark, its a little in-balanced to me!!!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/452745-finished-pc-help/#findComment-6071844
Sig under construction.
https://linustechtips.com/topic/452745-finished-pc-help/#findComment-6071847
Thanks for all the feedback! Ill add this to the build!
What motherboard would you suggest me getting?
https://linustechtips.com/topic/452745-finished-pc-help/#findComment-6072040
