I have 2 houses that are about 120 yards apart. It is a fairly noisy area. About 3-5 networks. It is not exactly a clear line of sight. There are trees in the way. And the antennas would be about 12-17ft in elevation difference. The Internet that I'm trying to send is anywhere in between 50mbps up to 100mbps. What antennas would you guys recommend
AMD A10-7850k, Cooler Master 212 EVO, Team 2133 2x4gb, V300 120gb, DVD, 3 HDD, MSI A88X-G43, Asus Strix GTX 970, EVGA Super Nova G2 850watt, Acer B326HUL
https://linustechtips.com/topic/452742-help-buying-advice/
directional ones
https://linustechtips.com/topic/452742-help-buying-advice/#findComment-6071830
