I thought this was a bot post for a second.
It seriously looks it. Not to mention some of it isn't in English.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6060670
Coming soon is one heck of a sponsor! I can't even find their website!
(jk)
This looks like it's gonna be awesome! Can't wait for it!
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6060689
why?  :)
Guys I'm Italian.. Sorry for my bad English.. if I don't write correctly, tell me  ;)
(jk)
Sorry I don't understand.. however soon new UP  :D
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6060751
bot post......
What leads you to think this? Some people might be worse at some things (english) but better at other. I see it as: He comes from another forum, or is completely new to this forum, creates an account because he wants to share his build with us.
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6061634
thank you  :)
I apologize for my English .. If you have trouble reading it, at least let me know where I'm wrong
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6061656
?? I don't understand .. What is bot post?
-snip-
Some people might be a bit too fast to think this when you have so few posts.
If people need proof, it shouldn't be hard to give it to them, have a piece of paper showing your forum name and the name of the build, inside the case? Not photoshopped or anything, raw real life paper.
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6061658
thank you  :)
A bit confused with "Soon new up" :P
I am guessing you are trying to say "More updates to come soon"?
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6061663
In bocca al lupo!  ;)
Good luck!  ;)
Guys, the word "up" in Italian is used as a noun, take "soon new up" as "new update coming soon"
Grazie :) A quanto pare sono finito nella tana del leone.. Non mi aspettavo questa accoglienza! E' il primo forum in cui mi capita  :lol:
You will understand that I'm not a bot, with the next posts of my work.
Now work is forward compared to what I posted here.
I have just registered here to show my work also on linustechtips.
Honestly, I never thought this reactions..
I hope you change your mind..  ;)
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6061805
Thanks! :) I hope that also the others change their minds :)
I like this build and I know you are a gpood, real person. That is why I have followed this post!  :)
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6062220
Small UP!
As you can see I had to move the cage inside of HDD, for reasons of space, since in the front I will install a radiator 360! I think I do later the holes. because those in case are not useful; so I can place the port HDD to a fair distance between the radiator and the power supply!
Now beginning to mask all the pieces and then paint it!
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6072341
Oh god! The dust on the first couple of pictures. I have loads of dust in my system as well, just too lazy to clean it :P
Can't wait to see how it looks when you've painted it! The renders were awesome
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6077197
Other UP!
Finally paint! I used a red metallic paint which comes closest to the Red Scarlet, I hope to look good color! Unfortunately from the photos the color is not exactly what it seems!
When I'll finish the work, I will do the photos with reflex and lights!
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6086958
Was gonna do a "Shut up and take my money" meme, but LTT doesn't allow for awesome imgurs..
Awesome progress!
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6087262
looking good man!
Awesome progress!
Thanks Guys  :D
Big Up :D
I unplugged, with the hair dryer, the label from hdd, I took me some time to not throw too much heat on the HDD, then to soften the glue have been there a good 5 minutes!
Then I put on the kit box of screwdrivers, the adhesive because I didn't know which on the surface to keep it for not to make him completely lose adhesiveness   :)
I masked the HDD to paint it quietly and then cut the upper ribbon with the cutter precision to cover only the part in relief and the inputs of the screws! Getting what you see in the picture above!
Here I gave a primer because it didn't take paint well, in fact I had to removing paint and do it again!
Black paint!  ;)
That's what I obtained! The edges could not come better than this! Then I touched up by hand with a brush and paint spray!
Now it masks the contrary! And paint red!
Here with cutter precision I gently removed the tape paper after first warmed a bit with the hair dryer! Always better to warm it up a bit 'otherwise you risk that take away the paint below!
Removed the first piece, no damage to the paint!   :D
Removing the second piece, painted screws and glued the adhesive after heating it! I put a pinch of attack where it didn't adhere! Usually it doesn't adhere on the tip that one removes first!
Here's the finished result! I hope you like it! If you have suggestions for improving the quality of my work didn't hesitate to tell me! I'm curious of your opinion!   :)
For the moment it's all about! At the next UP! :D
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6112101
That's looking nice.
https://linustechtips.com/topic/452011-project-scarletti/#findComment-6112577
