Search In
  • More options...
Find results that contain...
Find results in...
Will the NH-D14 fit in the Fractal Design R4 Case?
Pretty much asking what the title says, will the Noctua NH-D14 fit in the Fractal Design R4 case?
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
Thanks!
If you are willing to spend that amount of money, take a look at some watercooling instead
A computer once beat me at chess, but it was no match for me at kick boxing
Don't think an h100i would beat a d14 and the only other option is custom loop which would cost a whole bunch of money
Even if the h100i (the only closed loop that compares to the d14) was slightly better under full load it is louder and about $20 more
Think the H100i performs better then the d14, cant remenber now.
But the really good thing about watercooler is that you get the heat directly out of the case.
If you do the same for the GPU and PSU, almost all heat produced in the chassi are expeled directly out of the chassi, making the need for extra fans very low and the motherboard temp really low
here is my arc midi with the NH-D14.. and they have the same chassis, basically.
airdeano
