What DAC/AMP or Sound card should i get?
Solved by EnsoZero,
Honestly if you want something that will last you a long time and you won't have to worry about upgrading in the future, Schiit Magni+Modi will be your best bet and it's just a bit over $200 all told.
Featured Topics
halfbood_drag0n ·
3
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
