How to Take microphone buzz out
Pcinacan
So i hvae the cloud l head set. but there is one problem. They have a buzzing nose like really bad. I would just turn down the mic but windows keeps boosting it to 100 :huh:  and it is a quit mic to begin with. I have the craptastic motherboard so i think it is my motherboard right? is there any software that dose this real time not post because i can fix that, but it is a pain in the butt. I hopefully will get a AT2020 or blue yeti for Christmas. I still do not know if i should get the at2020 or yeti.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
Fine no answers i got  it
If it's a USB microphone then make sure you have it plugged directly to the USB ports in the back of the motherboard. The front USB ports usually have a lot of interference. You could also use a noise gate to block out some noise as well
