Load temps?
Go to solution Solved by Enderman,
Yeap that sounds about right! On colder days (30c) the load temps stays ard 80c! So im fine right?
yup
they get 70C with a 20C ambient
if your ambient is 30C, then you do 70C+10C and get 80C, so that's exactly right :)
What's a normal trix 290x load temp with am ambient of 32-35c?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/449485-load-temps/
should be ~75°C at that ambient temp.
Mine runs at 85c with mx-4 thermal paste D:
https://linustechtips.com/topic/449485-load-temps/#findComment-6026216
definitely over 80-85C with that ambient temp
this is corrected to 20C^^^
and thats a 290, not 290x
https://linustechtips.com/topic/449485-load-temps/#findComment-6026230
https://linustechtips.com/topic/449485-load-temps/#findComment-6026254
yup
https://linustechtips.com/topic/449485-load-temps/#findComment-6026291
yup
Last question! The 290x outputs more heat than the 290 right? :D
Thanks for the closure!:)
https://linustechtips.com/topic/449485-load-temps/#findComment-6026300
Thanks for the closure! :)
yeah, unless the 290 is overclocked higher than the 290x is
https://linustechtips.com/topic/449485-load-temps/#findComment-6026321
