Budget Of $2500 For Just Pc No Peripherals
Stick to my original build as much as possible Please summit tips and ideas not a whole new build
All Prices in Canadian
Everything in my current Build is Compatible
Here is my build
I am Overclocking
http://ca.pcpartpicker.com/p/4Z8RP6
I might Get Rid of One HDD and get a 8350
https://linustechtips.com/topic/448678-help-with-new-build/
Please don't do that
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016312
Here is my build
erm
do you even fan?
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($119.99 @ Newegg Canada)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($265.35 @ Amazon Canada)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($115.98 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($126.98 @ Newegg Canada)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($854.99 @ Memory Express)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($87.25 @ Vuugo)
Total: $2310.97
Generated by PCPartPicker 2015-09-12 14:50 EDT-0400
Put whatever else you want into your fan fetish you have...
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016318
You already made too may threads about it before, didn't I tell you that all this airflow was unnecessary and will do more harm than good. Think of all the noise it will make.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016328
Here is my build
I am Overclocking
someone just ban this fucking troll, holy shit brain cancer.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016337
erm
do you even fan?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($429.95 @ Vuugo)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($155.49 @ DirectCanada)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($154.99 @ NCIX)
Total: $2310.97
Get this and save yourself a ton of trouble. Also with the left over budget you could get a different case. Like a NZXT H440
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016351
I Do not care about noise
Lol are you trying to make a jet engine you would probably hear it from outside
        Setup
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016353
I am not trolling this is a serious build I want t go AMD but I could go skylake
Don't get products from certain companies because you like them. Get products that are good.
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016357
Just don't be stubborn and a fanboy, unless you like massive bottlenecks then by all means get a FX and 10 billion fans and see what happens
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($329.98 @ DirectCanada)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($148.25 @ Vuugo)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($295.50 @ Vuugo)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($154.99 @ Memory Express)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($219.00 @ Canada Computers)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($924.98 @ Newegg Canada)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($134.99 @ NCIX)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($174.98 @ Newegg Canada)
Total: $2442.42
Generated by PCPartPicker 2015-09-12 14:54 EDT-0400
        Setup
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016362
You need like a max of 7 fans in a PC. 4 for exhaust 3 for intake. I'd see no point in more then that.
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016363
FINE THIS IS CLEARLY NOT GOING TO WORK ANY TIPS ON THIS BUILD
http://ca.pcpartpicker.com/p/ngJHMp
Woo we're getting somewhere. I'd take a look @Ronnie76 build
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016371
WHAT?!?!? a fx6300 with fury x is the dumbest idea you can have. And why so much fans?
edit: at least get a top end fx series cpu and you don't need the wd blacks
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016387
Edit New budget $3500 With Peripherals
How About This Build
Different Case and Board?
not found Link is broken
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016407
Somewhere, SSD needs to change (850 Evo), PSU needs to change, Mobo is a bit overkill
oh get a non reference 980Ti
http://ca.pcpartpicker.com/p/vk6cnQ Hows this I want White and Red I will be painting case TO have red Accents
https://linustechtips.com/topic/448678-help-with-new-build/#findComment-6016433
