Uh.. possibly, but chances are it will work.
Maybe open it if you are sure there is still water inside. and let is completely dry.
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6009934
isn't every guide saying that you should only have the pump connected while filling the loop?^^
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6009940
if it wasnt formatted prior then no format it but that seems too simple and im sure you've already formatted it. best case scenario sata power cable is bad worst case dead ssd id just try a different cable if you have one first then try putting it in rice to get moisture out hope it aint dead bud.
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6009945
So, my SSD got a drip of water on it when my loop was filling. and It seemed to have gotten onto the SATA power plug pins. the SSD wouldnt show up in windows, so I soaked it in 100% alcohol and am currently letting it dry.
Chances its dead?
Put your SSD in a bag of uncooked rice, the rice will absorb all the moisture.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6009963
if you powered the ssd on while there was still any water left in it you may of fried it. I would take off the ssd's cover and check for corrosion, mineral deposits. I would clean any of that off with some IPA and then let it dry for a while then try again.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6009995
Wait, you soaked your SSD in alcohol?  :blink:
Alcohol evaporates really quickly.
Though frankly, I would recommend you open it up if possible, and pop the whole thing in a bag of uncooked rice, the saviour of soaked small-scale electronics.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6010052
Doesn't need too be small scale, I've seen it done to a 40 inch TV
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6010097
......That must be one huge bag of rice.
Did you ransack the Uncle Ben's factory? :P
DAYTONA
https://linustechtips.com/topic/448177-wet-ssd-help/#findComment-6010142
