Ultra 1440p Build Help.
Solved by jimakos234,
This build is a complete overkill
What good is X99 5960X if all he wants is to play games on ultra at 1440p?
Even one 980 Ti is enough.
You know what, if the OP doesn't mind throwing money around, I'll build a system that can do all he wanted for 1500 dollars less and he can give me the rest if he dislikes his money so much.
As op said:
price is virtually no object. I would say a max of 4,000.
If he wanted cheaper ,i would do cheaper.
My build can support even 4k on ultra.
