I have a WD Blue HDD and I have it installed it in my build.  It isn't being shown in my bios and in the "my pc" section of my files, however it is in my device manager.  Help?
Processor Intel Core i5-4690K CPU Cooler Cooler Master Hyper 212 EVO Motherboard MSI Z97-G45 RAM 8GB G.Skill Ripjaws X Storage Samsung 850 EVO 250GB SSD WD Caviar Blue 1TB HDD Graphics Card EVGA GeForce GTX 970 Case NZXT Phantom (Black) PSU Corsair CX600M Operating System Windows 10 Monitor BenQ GL2760H Headset Skullcandy PLYR 1 & Sennheiser Momentum
https://linustechtips.com/topic/447686-hard-drive-not-being-recognized/
Initialize the hdd.
Or it is faulty.
I don't have another computer to test to see if it is faulty.
Follow your topics.
Try checking if power is connected properly.
If it is a new HDD you need to go to Device management and create a drive letter for as well as a quick format before you start using it.
@multitasker451
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
Check disk management.
1. If it is there but nothing else you need to initialize it.
2 .If it is there and it is not allocated, you need to format it.
3. Format it, give it a driver letter
4. if nothing of the above, it may be faulty
The site has changed....
It is not there
post-167206-0-46251000-1441929247_thumb.
Hey there multitasker451,
I'd try swapping SATA cables and ports and see if it gets recognized in BIOS. Try resetting your CMOS battery and see if that helps.
Could you post a screenshot of the way the drive is seen in Device Manager? I'd try to find another computer to test the drive with WD Data Lifeguard Diagnostic to see if the problem comes from the drive or somewhere else in your system. Here's a link to the tool: http://products.wdc.com/support/kb.ashx?id=45gURy
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
