Can you squeeze in a Samsung 850 evo instead? Cause it is a lot better.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999420
here i edited it a bit, PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($180.99 @ NCIX US)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($49.99 @ NCIX US)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory  ($35.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($41.99 @ NCIX US)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($314.98 @ Newegg)
Power Supply: SeaSonic S12G 550W 80+ Gold Certified ATX Power Supply  ($89.80 @ Amazon)
Total: $824.72
Generated by PCPartPicker 2015-09-10 12:01 EDT-0400
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999427
This would be better for the same money:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard  ($59.00 @ Newegg)
Memory: Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($50.89 @ OutletPC)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case  ($59.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ NCIX US)
Total: $843.70
Generated by PCPartPicker 2015-09-10 12:03 EDT-0400
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999428
is the hyper X one fine? replacing this one?
and will the i5 6600k with ddr4 reap more benefits using an r9 290?
get an ssd from crucial, samsung, intel, sandisk(those are just what most people recommend) and you won't see much benifit from skylake and ddr4
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999438
HyperX is fine
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999439
Total: $843.70
i think i will order this one, thx bro, :)
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999466
If you want most reliabity and consistent performance get Samsung or Intel drives
<THE SILENT ASSASSIN>CPU(Intel i5-4690K)||COOLER(corsair H100i)||MOB(asus Maximus VII Hero ATX)||RAM(16gb of corsair vengeance)||STORAGE(Intel 530 128gb)(Samsung 850 Pro 500gb)(WD 2tb Black)||GRAPHICS(2 x Asus strix 970)||CASE(Nzxt H440)||PSU(Corsair RM750W)>http://pcpartpicker.com/b/Bbpbt6
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999473
You're welcome, hope you enjoy your new build =)
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999481
you could go for 8GB of RAM and put an unlocked I5 in there
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999509
difference between 8 gigs of RAM and 16 is around 20$, the cheapest unlocked i5 is 50$ more, it would also require a better motherboard
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999537
you could d the 4690k and a z79-hd3 for around 300 total
Solitaire.
https://linustechtips.com/topic/447470-new-build-help/#findComment-5999568
i might upgrade to 12gb in future bro but getting an unlocked i5 will require a better mobo unfortunately or it wont reap any benefits!!!
12GB is not a good idea. How dou you wantz to get that 3x4GB sticks. Doin that is not advised. all or nothing. 8 or 16 GB
3.Use
https://linustechtips.com/topic/447470-new-build-help/#findComment-6000237
