type it out
i will solve
with my super op online calculator
its called "google"
Not particularly helpful when doing math and you need to see what a solution is and how it has been made.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/446961-math-help/#findComment-5991348
oh, if you need to find out how to do it...
im still in algebra 2
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/446961-math-help/#findComment-5991356
Been stuck on this separable diff eq for the longest time and I can't solve it. What do?
1) Where did the minus sign on the e^x go from step 2 to step 3?
2) Factor it out. It will be easier on you in the long run. It easier to integrate e^y+2+1/(e^y) than it is to do it to a complex multiplication.
3) Go from there.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/446961-math-help/#findComment-5991367
Also; follow your posts.
https://linustechtips.com/topic/446961-math-help/#findComment-5991374
3) Go from there.
Oh whoops forgot the minus sign. Ty. I will try that
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/446961-math-help/#findComment-5991414
