No, the 5820k on the x99 platform would be the way to go.
The most you get on LGA1150 is a 4790k (4 cores, 8 threads), which is still plenty for gaming and editing (if you're not editing as a profession, then even an i5 is more than enough).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/446501-help/#findComment-5984818
Any good i7 6 core processor? (for gaming/editing) socket 1150.
LGA1150 only the 4790k which has 4 cores/8 threads.
i7-5820k is the best bang for the buck 6 cored i7 but it's on a relatively expensive X99 (LGA2011-3) platform so not everyone can afford it.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/446501-help/#findComment-5984826
i7 4960X. But I think that one is hard to come by and not sure how good it is.
Take a look at the X99 platform, with the 5820K for example. (you will need to use DDR4 though)
https://linustechtips.com/topic/446501-help/#findComment-5984846
a 5820k is, for the most part, on par with a 4960x and usually cheaper (assuming you don't need more than 28 lanes).
The 4960x is also on X79.
PSU Tier List | CoC
https://linustechtips.com/topic/446501-help/#findComment-5984859
Okey, a 4790k it is! Would you recomend and AIO liquid-cooler or a good traditional cooler?
Whichever you prefer aesthetically.
Something like an NH-D15 /Dark Rock Pro 3 are basically on par with most 240mm AIOs. (the downsides to an AIO are usually cost and the extra failure and noise point being a pump)
PSU Tier List | CoC
https://linustechtips.com/topic/446501-help/#findComment-5984872
