Okay first off my hardware not sure if needed):
Intel i7-4790k
Asus Maximus Hero VII
EVGA GeForce GTX 580 Classified Hydro Copper (x2 in Sli)
Corsair ax1200i
I'm planning on using mostly EK products, but I'm unsure as to what pump to get. I'm going to have 2, 360 Rads and a EK 250 res.
The Cpu, gpu's and motherboard will be cooled. I was looking at EK's D5 pumps with pwm, would that be enough?
Oh and I'm using 12/16mm PETG for the lines.
https://linustechtips.com/topic/444507-pump-recommendation-for-custom-water-loop/
the d5 pump is the best
if you can get it, go for it
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Intel i7-4790k
Corsair ax1200i
D5 :)
Get the EK XE rads if possible, got good reviews on extremerigs. Their fans Vardar stuff, is also meant to be quite good.
"Use the force Harry"
                   -Gandalf
D5 all the way
D5 :)
The vardar fans are loud and have bad performance for their noise level
Also they dont make the most pleasing motor sound
Definitely get noctua/bequiet/fractal design/noiseblocker instead if you want quiet
