higher power supply needed since the 970 gulps more than 200w i suspect and corsair lel but yeah i think its ok but why not get the 4690k?
i7 5820K @ 4.4GHz | Evga GTX 980ti Superclocked | MSI X99 Sli Plus | 16GB Crucial Ballistix DDR4 | EVGA 850W Gold+ | 2TB HDD and 250GB SSD
NZXT Phantom 530 | Corsair H100i GTX |
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956510
Don't get sli 970's get a single 980.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956515
Not really - for 2 970s - you need at least 650W and I recommend 700-750W - those cards use around 220W each.
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956517
so everything is good except for the ps
The build? Not really - get a 4460, skip the cooler as the stock one is enough - get an EVGA G2 or GS - CS are mediocre.
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956534
Also - if you want dual GPU - get 2 390s - more than double the VRAM, more horsepower and flat out better offer for a CF build. They would need about a 750W PSU
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956539
is everthing else good other than the ps
should be but 2 970s are equivilant to a 980ti pretty much, why not just buy 1 980ti?
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956541
the sale makes it cheaper then 1 980ti.
Still not worth for SLI with that 3.5GB of VRAM
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956562
7.0 gb still not bad and i only need it to last 2 years at 1440p
VRAM doesn't stack - if you bought 4 970s you would still have 3.5GB usable VRAM since each card has to duplicate everything for itself
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956585
Saying why not get a 4690K would be like me saying "Why not get a 5960X?" to you.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956586
so, did no one realise the motherboard doesnt support SLI?
EDIT: and only has one PCIe 16x physical slot.
Now that you mention it :D
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956696
it worries me no one checked that.
it immediately caught my eye because on the intel side only the Z chipsets have boards with SLI support for some reason.
I'm not a fan of multi-GPU so I forget to check :D
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956739
me neither, but i generally "prepare" builds for the case it might happen, which usually leads into Z97
True - but I generally advise people to stay away from CF or SLI
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956766
i'm more of an "it might happen one day" person.
imagine the 1000 series nvidia magically has perfect scaling. i'd pick up two cards if that happened.
https://linustechtips.com/topic/444464-gpu-help/#findComment-5956778
Moved to Graphics Cards.
https://linustechtips.com/topic/444464-gpu-help/#findComment-5958242
