Hey yo guys, so i was going to clean my laptops fan, but it got ESD damage. Now that im building a new PC idk if i should pay someone for building it or if i sould build it anyways???
Tnx dawg :P  :P  :P
I'm part of a business that can build it for you but I can't give you links because CoC :P
Just wear an anti-static strap if you're very concerned. Plug in your PSU, make sure it's sitting in your case and is set to ON and attach the strap to your case.
I remember my first time :) you'll be fine
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
You can do it man, just ground yourself, either keep one hand on your power supply, dont stand on carpets, or buy an antistatic wrist strap and/or mat on amazon for like $10, I think its worth it. :)
nah just take your clothes off
removes a huge % of getting static electricity
why? b/c i build 4 computers without shirt/pants just me and my undies and  a handy dandy screwdriver
of course! how could I forget the most important step of them all? take off all your clothes and make sure you do it outside, or at least where theres a lot of light, or else your get super static from the dark particles. no, honestly as long as you have your bare feet on a wood or stone floor, or you're grounded with a wrist strap attached to the case or power supply, you'll be fine. and honestly if your worried a local computer place could build it for you if you just buy the parts and ask them nicely, usually they will tell you the extra $50 or less. its never that much and usually you can get a warranty with it./
