Hi Guys,
I need to buy a power bank for my Moto G 2nd gen.
Im looking at something around the £15 range.
Doesnt have to be too big.
I want it to charge nice and fast (output and input)
It should be fairly thin and small, weight isnt a big problem.
I would like it to fit in my pocket.
Thanks
Gershy13
CPU: Ryzen 7 5800x + H150i Elite LCD
RAM: 32GB Corsair Vengeance Pro RGB DDR4 3600MHz CL16
Motherboard: Gigabyte X570 Aorus Pro
GPU: MSI RTX 3070 Ventus 3X OC
SSD 1: Corsair MP600 1tb (Windows)
SSD 2: Samsung 840 EVO 120gb (Scratch Drive)
SSD 3: Samsung 860 EVO 250gb
HDD 1: WD Blue 1TB
HDD 2: Seagate Barracuda 2TB
Case: NZXT H710
PSU: Corsair TX750M
Mouse: Lamzu Atlantis Pro Mini 4khz
Keyboard: Akko 5075B Plus
OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/442472-best-power-bank/
Hi Guys,
Look into Anker, great company for stuff like that
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930247
Hi Guys,
Thanks
Gershy13
http://www.amazon.co.uk/5200mAh-Compact-Portable-External-Technology/dp/B00P8SY7HQ/ref=sr_1_2?ie=UTF8&qid=1441190426&sr=8-2&keywords=anker
bump the price up a little bit
http://www.amazon.co.uk/16000mAh-Portable-External-Technology-Motorola/dp/B00D5T3QK4/ref=sr_1_1?ie=UTF8&qid=1441190426&sr=8-1&keywords=anker
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930254
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930270
The 5200mah is a bit small... i would like something a bit bigger.
However the 16000 is massive! but £20 a bit too much...
How is aukey?
http://www.amazon.co.uk/607/dp/B00UL6MUMY/ref=sr_1_7?ie=UTF8&qid=1441191110&sr=8-7&keywords=aukey
aukey is also a good brand :)
Old Rig
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930303
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930310
I really love my anker since it has that IQ charge technology which prevents overcharge
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930327
which one do you have?
also nice pic ;)
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930332
also nice pic ;)
the Anker Astro E4, would buy it again
Thx
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930345
Thx
hmm that looks ok too...
It might be a bit big tho... to fit in my pocket..  :P ladies.... :P  (Barnacules Nerdgasm reference) :D
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930357
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930485
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930527
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
https://linustechtips.com/topic/442472-best-power-bank/#findComment-5930530
