Good cooler less than $30?
Go to solution Solved by Opeth747,
212 Evo
Hyper 212 Evo.
https://linustechtips.com/topic/442108-good-cooler-less-than-30/#findComment-5925418
Have your answer yet?  If you're a bit cheaper the 212+ works perfectly fine if they still make it (last I checked they do).  It's not watercooling, but it's nice and cool for what it is.
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
https://linustechtips.com/topic/442108-good-cooler-less-than-30/#findComment-5925433
Hyper 212 evo.
Best budget cooler.
PERIOD
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/442108-good-cooler-less-than-30/#findComment-5925481
