Hello!
I'm building my first PC and i need some advice and recommendation, i am semi familiar with the components and building process by watching tons of Linus videos on YouTube and i really want my own build then to buy from the store and i am on a tight budget of 1000 Euro 1100 max! so this should make my PC less expensive and more powerful i will use it mainly for games and some Photoshop. Anyway from all i could gather and with few personal choices i made a list of parts and i need to know if what i chose is optimal and if i need to change something and overall recommendations will be highly appreciated.
CPU: Intel Core i5-4690k  / I heard its great for gaming and can be overclocked easy i wont do much of video editing so i wont benefit from Core i7 and multithreading.
CPU CoolerTacens MARS Gaming MCPU2 or Cooler Master hyper 212 Evo /  I know the 212 Evo is little better and they are the same price 30 Euro here but the MCPU2 just going to look really good with the rest of the build that's why i consider to buy that.
MotherboardMSI z97 gaming 3  / I like how it looks and and i don't know the difference between Gaming "3" and "5" but cheaper "3" support Crossfire and overclocking and that's all i need, will allow me to upgrade with 2nd Video Card later on.
RAMKingston HyperX Fury Red DDR3 1866MHz PC3-12800 2x4GB  / I don't know if its better to put 2x8GB or stick with 2x4BG simply because i want to cut the money somehow and when i have extra ill put 2 more 2x4GB and with 16GB i wont have problem at lest that how i see it for me.
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM
SSD: Kingston SSDNow V300 Series 2.5 240GB  / Its the cheapest 240GB i could find.
Video Card: MSI Radeon R9 390   / First i was going for GTX 970 but then i read about it and the VRAM issue at the same time i come across the R9 390 at the same price with 8GB and later games might take advantage of all that VRAM and i don't know if i understand that correctly but putting 2nd card don't doble the VRAM so the 970 might lack on VRAM in later games with R9 390 would be ok, and the only complain i sow about it was the drivers but seeng its new card the drivers will come if they din't already, also i found that Crossfire Motherboards are cheaper then SLI compatible this let me save some money on Motherboard
Case: NZXT S340 Red  / "Stuff that doesn't suck" and actually fit in my budget thanks Linus!
Power Supply: CX 600W CORSAIR BUILDER V2 80+ BRONZE ATX.EPS12V  / I run a power supply calculator and i included that i will overclock the CPU and GPU and it was recommended 600W for my build i know ill have to update it when i put 2nd video card but that wont be soon and i need to save money i just hope 600W is enough for overclocking the CPU and GPU maybe someone could tell me because as i said its my first PC and i have no clue.
Monitor: Here i need some recommendations all i know is that i need IPS 22-23 Inch 1080p if anyone can recommend me any for around 150 Euro or 160$ cheaper better!
Keyboard: Here again no idea but i am looking for cheapest Cherry MX Red
Mouse: No clue for Mouse need something cheap good and for someone with big hands, Wireless is a BIG + for me i don't play FPS or competitive gaming but i don't want to jump at the first store and crab crappy mouse also  :)
https://linustechtips.com/topic/442082-pc-build-help/
Hello!
MotherboardMSI z97 gaming 3  / I like how it looks and and i don't know the difference between Gaming "3"and "5" but cheaper 3 support Crossfire and overclocking and that's all i need, will allow me to upgrade with 2nd Video Card in few years
Solid build. But I would suggest a different PSU. Anything but the CX series
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5925081
I would not even touch that PSU...
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5925458
Hello!
Nice build for the provided budget, again just get a different power supply. I would strongly recommend EVGA's power supplies. Other than that nothing else needs changed! :D
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5925515
Everything looks good.
Get the EVGA G2/B2 PSUs.
Worthy investment for your build.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5925561
I have the same question. So, I have a PC build I plan to get, and I was hoping to get some advice on my build and if there are any recommendations, or if something is complete crap, and I should change it. My intentions for this build is to play most or all games at max settings at 1440p while staying below $1700. Also I have to ask if I should go for water cooling too as a huge priority, or should I get it later down the road? Anyways.. The specs are as follows:
Here is the link, I don't have time to write it all out: pcpartpicker.com/p/GtC9mG
Thanks in advance!
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5935502
Thanks in advance!
All i can recommend is changing the GTX 970 4GB with MSI Radeon R9 390 8GB due to the more VRAM now is fine for all the games with 4GB but later games might need more and actually the GTX is with 3.5GB and 0.5BG-slower memory or something but i'm not so sure how that works.
https://linustechtips.com/topic/442082-pc-build-help/#findComment-5938834
