So I have a couple of media devices that connect to the internet using Ethernet ports and i dont want to run wires from one side of my house to another. Is it possible to make the connection wireless?
Get a Wireless USB Adapter?
What are the media devices? If you can add a wireless adapter to them (e.g. as an internal PCIe card or an external USB stick) you could connect them wirelessly to a router on the other side of the house. If that's not an option, you could connect the media devices with Ethernet cables to a wireless device in the room they're currently situated in, then communicate with a wireless router on the other side of the house that way. If you want more specific advice you'll probably have to provide more details, please.
It is very difficult to give anything but vague answers to vague questions.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
They're bluray devices and the boxes that connect to my home theater
I just bought this as I'm moving house next week and need LAN ports in the other room, so until I get round to wiring up the house.
This is my solution: http://www.ebuyer.com/519415-tp-link-n600-universal-dual-band-wifi-ethernet-entertainment-adapter-with-4-tl-wa890ea
