Not sure what you're exactly referring to. When putting the problem into Wolfram Alpha, it comes out to be 3x2+2h. Because both terms are being added together, and they're both positive, your parenthesis drop and you simply combine the terms together.
@Speedstack79. Think about the Associative property.
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900380
@ind3x  @Godlygamer23
You're right, (x²+h)+(2x²+h) equals 3x²+2h, what makes you believe that it shouldn't?
I don't really undestand your attachment.
the original equation is dYZnFHu.png if x is 2 and h is 4, then the answer should be 48
if you plug in 2 and 4 into 3x²+2h you get 20 and not 48
person below me is a scrub
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900461
That's correct. Using Wolfram Alpha, they get the same answer. 20.
post-7355-0-98185500-1440884624_thumb.pn
post-7355-0-53072500-1440884646_thumb.pn
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900531
attachicon.gifScreenshot_2015
when I enter the equation enter wolfram ( http://www.wolframalpha.com/input/?i=x%5E2h+%2B+2x%5E2h ) it gives 2hx   which gives 48 if x = 2 and h = 4 ; which is what the original equation also gives... my question is why x2h + 2x2h  does not group to be 2h
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900605
if x=2 and h=4
x^2*h would be 4*4=16
2x^2*h would be 2*4*4=32
in total 48
you could simplify it to:
h(x^2+2x^2)
h(3x^2)
4(12)=48
This is the simplest i can make it :)
When in doubt: C4
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900608
-snip-
Because it's two different terms.
Therefore you can't simply add it together (like i did wrongly in my first post)
You can simplify it as i do right above this post.
When in doubt: C4
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900627
Your original expression was this: (x^2+h) + (2x^2+h)
Now it seems that you're changing the expression or becoming confused by your own post.
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900665
when I enter the equation enter wolfram ( http://www.wolframalpha.com/input/?i=x^2h+%2B+2x^2h ) it gives 2hx   which gives 48 if x = 2 and h = 4 ; which is what the original equation also gives... my question is why x2h + 2x2h  does not group to be 2h
The text in your post and your attachment show different terms.
Is it "(x^2+h) + (2x^2+h)" we're talking about, or
"x^2*h+2x^2*h"?
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900690
ooh, I forgot how terms worked ;
@everyone who responded
https://linustechtips.com/topic/440136-simple-math-help/#findComment-5900703
