Hey everybody, so I am starting school soon and just now realized that one of my classes has required software. (I know, should have researched better ahead of time blah blah...). SO I need to find a laptop that can run Solidworks 2015, looks like it needs windows 7 (8 preferred), 64 bit, and preferably 8gb of ram. Was considering a Lenovo G50 with an AMD A8 in it, starts with 4gb of ram but upgradeable to 8.
Any other suggestions? I am also buying books currently so I am looking in the 300ish price range or less.
Thanks!!
Edit 1: newegg link http://www.newegg.com/Product/Product.aspx?Item=N82E16834319445
So, signatures are a thing. How does one do them? Is this right?
https://linustechtips.com/topic/439818-school-laptop-help-pls/
the G50's great from what I heard.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/439818-school-laptop-help-pls/#findComment-5896387
http://www.amazon.com/Dell-Latitude-E6230-12-5-Notebook/dp/B00YW6KQSE/ref=sr_1_5?s=pc&ie=UTF8&qid=1440847920&sr=1-5&keywords=laptop&refinements=p_n_feature_five_browse-bin%3A7817224011%2Cp_36%3A-35000 , Its a certified refurb. Seems decent it has 8gb RAM, i5 3320m, 256gb SSD (You are better of upgrading that if you need more space).
I have an i5 and many other things
https://linustechtips.com/topic/439818-school-laptop-help-pls/#findComment-5896441
thank you for the lookup sir, I appreciate it a lot. Looks like a good deal, specs are in line with what I should need. Now if school was only less expensive lol... At least I can get half the books I need and the laptop right now. Still got a couple weeks to finish getting books together.
Anyways, appreciate the help again!
https://linustechtips.com/topic/439818-school-laptop-help-pls/#findComment-5896457
No problem. Good Luck in school!
https://linustechtips.com/topic/439818-school-laptop-help-pls/#findComment-5896470
AYE! My whole college uses that model of laptop, well the staff I mean!
CPU: Intel I7 4790k @ 4.6Ghz 1.255v | GPU: Gigabyte G1 Gaming GTX 980 Ti | Display: Acer XB270HU bprz | RAM: 16GB (4x4GB) Gskill Ripjaws X 1866MHz | CPU Cooler: H80i | Motherboard: MSI Z97 Gaming 5 | SSD: Mushkin 120GB + Sandisk 480GB | HDD: WD Blue 1TB | Case: Enthoo Pro |PSU: Seaconic M12II EVO 850w | OS: Windows 10 64-Bit | Mouse: Logitech RGB G502 | Keyboard: Thermaltake Poseidon Z (Brown Switches) |
https://linustechtips.com/topic/439818-school-laptop-help-pls/#findComment-5896483
