I am asking because the AC/heater at my house is broken it is going to cost way more to fix than i can afford right now.
I will fix it next year with income tax.
But to get through the winter i have decided to take my old pc's i have lying around and set up as many as needed to keep my room warm.
If it helps most of my old pc's are OEM,single core 1.4ghz-3.2ghz(3 AMD,5+ Intel i think),with OEM 250w PSU's,and still in the crappy OEM case's.
If you guys need exact models of the cpu's i can try to find out,but it may take 15+ minutes,just let me know if you need it.
| I7 2600@4.2Ghz | Corsair A70 w/H100 fans | 16GB DDR3 1333Mhz | MSI Z77A G45 Gaming | Corsair TX650 | XFX R9 380 | 2x 120GB Samsung 840 SSD in RAID 0 | 2x Seagate 500GB in RAID 0 | 750GB Seagate | 500GB WDHDD + 500GB WD USB HDD | Sound Blaster Recon | Antec Sonta Case | HP LP2480zx @1920x1200 | Acer H243H @1920x1080 | BenQ EW2440
https://linustechtips.com/topic/438833-how-much-heat-does-a-computer-output/
You would be better off (both economical and amount of heat) to buy a room heater of some sort.
My Computer
Beef Cake
Intel i5 4690k @ 3.5GHz - EVGA 970 FTW - ASRock Z97 Extreme3 - Kingston HyperX Fury 8Gb 1866MHz - 120GB Samsung Evo - 1TB Toshiba Drive - 320GB Samsung Barracuda - Corsair 500M
How much do you wanna pay in power though? and how low do temps get?
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
if i were you i'd just use a hairdryer. it uses less power and makes more heat
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
Actual space heaters are a lot more efficient at producing heat. So the best option would sadly be to get something small and cheap (check craigslist).
Computers does however produce heat, but it's not nearly enough to heat up a whole apartment.
If you're not able to get a proper space heater, then I would probably just use the main rig for Folding. And put on an extra layer of clothing.
You'd be better off with a crazy machine that has 4x crossfire reference 290Xs. that's a 1400W space heater right there :3
When it's chilly I hardly notice my single 290(OC), unless I turn my computer so the exhaust fan blows on me. Then it's nice and cozy. :3
But when it's already 90F in my room, it's awful. Almost moved my computer outside the door and had my desk on the inside.
CPU: R7 1700 @ 3.875GHz/1.335v , GPU: Fury Nitro.
if you really want a space heater pc go buy a amd fx 9000 series and watercool it to get the maximum amount of heat out of the pc into your room
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
I snuggle with my laptop at night during winter while having it render. It's nice ^^
the problem is that my room is small and because of that very crowded,and i would be worried about something either melting or catching on fire.
With how things are money wise,i would rather a slightly higher costs over time than a upfront cost,and temps in the winter i think get to around 60f give or take a few,i know it is cold enough that sitting for a long time at my pc wearing socks,sweat pants and a t-shirt,and i still get cold enough to need a blanket.
And to those that say that 60f is not cold i live in texas,so it is cold to me.
Why should he take reference cards? He should take aftermarket cards and OC the hell out of them to make them draw even more power.
GPU: Gigabyte GTX 970 G1 Gaming CPU: i5-4570 RAM: 2x4gb Crucial Ballistix Sport 1600Mhz Motherboard: ASRock Z87 Extreme3 PSU: EVGA GS 650 CPU cooler: Be quiet! Shadow Rock 2 Case: Define R5 Storage: Crucial MX100 512GB
Because the reference cooler takes all that heat and dumps it out of the machine through a single vent in the card. Instead of keeping the card nice and cool by dissipating the heat throughout the machine.
The heat still ends up in the room either way.
It should work fine in Texas. I would trust a computer over an actual space heater. It won't be super warm but it should take the edge off.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
Ok i am going to do my best to remember as many of the systems as i can.
2.4ghz amd sempron,1gb ram,nvida 7900gs
2.4ghz amd athlon 64,2gb ram,ati hd 4650
3.2ghz intel celron,2gb ram,no gpu
1.5ghz intel celron,512mb ram,no gpu
1.8ghz intel pentium 4,512mb ram,no gpu
1.4ghz intel pentium 4,512mb ram,no gpu
1.3ghz intel pentium 3,512mb ram,no gpu
Dual 2ghz xeon w/HT 3gbram,no gpu
other than those i have 3 system that will power on but not post,and one that is unstable and boot loops no matter the OS,all due to dead mobo's,but idk if they would produce much if any heat if i left them running.
No Post:
2ghz intel pentuim dual core,3gb ram,no gpu
2.2ghz phenom 1 quad core,4gb ram,amd 7750
3.6ghz amd fx-8150,8gb ram,270x(this system also has a 1000w PSU,and i have a dead 7970 that will not post but the fans spin,so if even running them without posting will make some heat i could add this gpu for more heat)
To you guys who don't think i should,i would rather pay some extra on my electric bill than a high upfront cost,plus i only want to heat my 10ftx10ft room by 10f-15f.
What would be the most efficient combo of these pc's to do that?
The faster the heat dissipation the faster the room heats up a better cooler doesn't mean less heat coming out.... same amount of heat just getting out into the air faster
I would have thought it would leave at least slightly faster coming directly out the back of the machine rather than being caught in the case for the exhaust fans to suck out. You could always point the computer the other way and have the vents blowing on your legs and feet :P
Do you have a main rig? at 60f you could easily warm that up enough with 1 or two of those pc's the only trouble being that crappy pc's don't actually produce that much heat, they just don't get rid of it fast
Pretty much any pc is equally efficient when used as a space heater. Almost all of the power a pc consumes is directly converted to heat.
I used a red ringed xbox under my blanket blowing up at me :3
