Hello I've installed my second gtx 970 and connected both with my sli bridge but the controll panel says that there is no sli bridge ? How can that be ?
CPU: Intel Core i7 9700k | RAM: 2x8Gb Corsair Vengeance RGB Pro | GPU: Asus GTX 1080 Strix | CPU Cooler: Corsair H100i RGB Pro | PSU: BeQuiet straight power e9 580W | MoBo: Maximus XI Hero Wi-Fi | SSD: 1x 1tb 1x 500gb 1x 250gb
https://linustechtips.com/topic/438003-gtx-970-sli-issue/
Broken SLI Bridge?
Also i love your profile picture :D
don't know i never touched it, but it looks okay.
haha thank you ;)
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871485
8d8b9cbda8f9472129be48ba9db6ac6a.png Make sure that one of the two slots is not the bottom one.
The bottom slot ^ is 4x only and Nvidia does not allow those slots to be used in an SLi configuration.
Make sure that all monitors are plugged in to the top most GPU.
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871537
ive plugged one in the top and the other right below and there running in 8x PCIE 3.0
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871573
i tried to use another sli bridge, nothing changes
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871584
It should be just fine.
Reboot and then open up the Nvidia control panel again. See if the option shows up again.
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871622
Have you put a power cable to each GPU?
yes and Geforce Experience is showing 2x Gtx 970 -,-
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871623
https://www.dropbox.com/s/rk0ra5rh4vxjmhg/Gtx%20970%20sli%20issue.JPG?dl=0
it says that i have to connect both gpu's with an sli bridge :(
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871686
Try using DifferentSLIAuto and see if it helps.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/438003-gtx-970-sli-issue/#findComment-5871781
