First workstation/gaming rig build
Go to solution Solved by manikyath,
Touché
http://de.pcpartpicker.com/p/y2bXrH
cutting down to Z170 will make up for the cost difference, and will actually outperform in badly threaded applications.
Hello everyone,
The question is what the title says, I'm looking into building a Workstation/game pc and I'm not sure what I should be picking parts wise.
I'll be working with programs like autodesk maya, photoshop, sony vegas, sidefx houdini and illustrator.
But, I'd also like to be able to play games on there.
These are the parts I have put together:
http://pcpartpicker.com/p/sxs4Vn
The main problem lies in the cpu, I'm not really sure what is better for these tasks starting with amd or Intel.
My budget is 2000 euro's.
A big thanks in advance!
https://linustechtips.com/topic/437917-first-workstationgaming-rig-build/
1. Swap out the 4770 for a 4790K.
2. Swap out the 850 Pro for an 850 EVO.
3. Swap out the SuperNOVA NEX for a SuperNOVA GS. 550W if you want to save a little more money.
4. Swap out the Seidon 120M for a 120V. Cheaper and higher fin density.
5. Swap out the Barracuda drive for a WD Red or Caviar Blue.
6. Consider the 230T as IMO it looks a lot better than the 200R.
Here you go bud. It's a bit over budget but it's totally worth it just to get the 980 Ti:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (€401.02 @ Mindfactory)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  (€124.39 @ Mindfactory)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard  (€210.60 @ Mindfactory)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  (€101.44 @ Mindfactory)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (€110.31 @ Mindfactory)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  (€134.61 @ Amazon Deutschland)
Video Card: Asus GeForce GTX 980 Ti 6GB Video Card  (€719.66 @ Mindfactory)
Case: NZXT S340 (White) ATX Mid Tower Case  (€85.64 @ Mindfactory)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (€68.14 @ Amazon Deutschland)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (€39.93 @ Mindfactory)
Total: €2034.45
Generated by PCPartPicker 2015-08-26 14:54 CEST+0200
Total: €2034.45
Thank you all for the help!
i see a problem here: while thats an impressive build, germany is one of the cheapest countries of europe, and prices will be a tad higher in NL.
5820K definitely. Unlocked, 6 cores, 12 threads vs unlocked 4 cores, 8 threads.
but the 4 cores are faster, so in badly threaded applications the 4 cores will win.
also, as you saw before the 4 cores are also significantly cheaper.
Yeah but for the games that do use all the cores... Holy shit. Over clock that son of a bitch and you'll be fucking flying my nigga.
thats where the lower wattage of a quad core comes in.
i want to see a 5820k clocked to 5GHz on air :P
