ASUS GTX 970 Weird Noise
Quido
Hello,
I turned off v-sync whilst playing a couple of games just to see what frame rate would be achieved and I noticed that my GPU makes a high pitched noise but this only happens whilst playing a game as when pauses occur the noise stops immediately and resumes just as quick when the game starts again. I wanted to see if it was the fans so I went into MSI Afterburner and played around with the fan speed testing a bunch of levels to see if it was a specific percentage that caused the noise but nothing. The sound that is made is never heard when doing this.
I dont understand what it is because surely putting the fan speed at 35% in game would produce the same sound as 35% on the desktop but there is a high pitched sound. I turned on v-sync on CS-GO and the sound does quieten down to the point that it is no longer noticeable but I would still want to find out what is causing it.
I am 100% sure that it isn't coil whine because as I said, spinning the fans up on the desktop doesn't produce this noise. To add to this, when using ALT+TAB the noise also immediately stops and doesn't come back until I go back into game. It could be a game issue as I don't seem to get this with GTA 5 or games that are also as demanding.
Thanks in advance.
That's coil whine. It's brought on by high loads, especially with higher framerates.
Coil whine isn't made by the fans, it's made by the electrical components on board. Mine does it too. The Strix card is notorious for it.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Different power supply's have different effects on coil whine with graphics cards, either replace your PSU or get sound proof headphones or Deal with it
My card did it quietly for a while, but it seemed to have disappeared or greatly reduced over time (or i just don't notice it anymore lol).
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
