PCPartPicker part list: http://pcpartpicker.com/p/YyNR3C
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.98 @ OutletPC)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($145.99 @ SuperBiiz)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.88 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($318.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ Micro Center)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($73.98 @ Newegg)
Monitor: BenQ RL2455HM 60Hz 24.0" Monitor  ($183.86 @ Amazon)
Total: $1106.65
Generated by PCPartPicker 2015-08-22 21:29 EDT-0400
What do you guys think???  :P  :P  :P
https://linustechtips.com/topic/435691-my-first-pc-build-d/
Improve PSU and get like beefier cooler for better OC temps
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839808
*thumbs up*, but for high end builds like this I'd get a better PSU (you only need 650watts though) like a gold EVGA or something. And you could get a better PSU.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839820
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839821
OMFG REALLY?!?!??!?!
i based my build on several gaming pc build youtube videos
CX power supplies, as stated in the video, are for basic system builds - they temperature tolerance is only 30*C and can cause issues real fast with a high end warm GPU. I'd strongly suggest EVGA or SeaSonic. Also, check the 390 since it's power is slightly above the 970 and has more than double the VRAM and with recent events it might have better DX12 support than the 970 - might, not will. Not sure yet.
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839843
A Gold certified?
Liquid cooling?
Hyper 212 Evo for CPU
SeaSonic for PSU
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839849
bruh i already have hyper 212 evo and yea im scared about my psu
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
Consult that list and get tier 1 or tier 2
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839872
i considered the 390 but i said nah f*ck amd  :P
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839873
Why so? Recently AMD have been quite a bit better at drivers and raw horsepower than Nvidia
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839882
do you want the ling of the vid i based most of my build on?
well here it is
i went for the i5, 1 970 and no ssd
Mush talks a lot but doesn't really say anything meaningful usually. I'd suggest skipping his advice.
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839902
yea i know but most of the high end build ive seen use intel cpu, but i also wanted the cance of upgrading to a core i7 down the line soo umm yea
intel CPU is what I advise - I was talking about the GPU :P
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839907
A Gold certified?
Liquid cooling?
get an evga 500b instead. Much better than a CX from corsair (god bless your system if you use it)
Or better yet if your budget allows the seasonic m12ii is amazing for it's price (get the 520w version)
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839921
M12II EVO 620W would be better since it has some extra headroom for OCing and future upgrades. the G-series is also good at that price point
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839927
shit
Btw - if only gaming get the 4690K - much better value
https://linustechtips.com/topic/435691-my-first-pc-build-d/#findComment-5839928
