How to clone hard drive with steam?
Solved by Captain_WD,
So I have a 1tb seagate hdd right now. Im planning to switch to 3tb and I have steam install on my ssd and most of the games on the hdd. if i clone the 1tb hdd, would it work with all the games? would it look just like I never replace anything?
Hey there Pooherino,
The cloning process creates an identical copy of the first drive onto the second one bit by bit. The system shouldn't tell the difference once you've swapped the two drives and the remaining 2TB of space should be indicates as "Unallocated" in the Disk Management. Do check if the 1TB HDD is formatted as MBR or GPT as if you clone it on a 3TB drive and it's configured in MBR, you won't be able to use the full 3TB storage space of the targer drive as MBR is limited to 2.2TB and you would have to reformat the drive in order to convert it to GPT.
Other than that you shouldn't have problems.
Captain_WD.
