Hi guys. So now i am about to build my new gaming pc. At first i had my eyes on the nzxt h440 razer edit because it was in the beautiful black finish. But now i want a white case to match the rest of my room. It is no problem find white parts to the build, but i am very confused about what case i should use. I have been thinking about a lot of different cases like the corsair graphite 380t, corsair carbide air 240 and the 540 as well. Also the nzxt h440 in white and even the corsair graphite 760t. I really want this pc to look clean with cable management and so. Which white case do you prefer? Please write it down below as well as some pictures of your white setups. :)
https://linustechtips.com/topic/435254-building-a-classy-white-computer/
Primo takes my vote.
That or a H440.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
I personally really like the 760t. Window is nice and features are great. BTW I would suggest getting a white power supply, check out the fractal design tesla r2 650w unless that doesnt meet your wattage range
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
h440 is known for bad airflow and it costs so much compared to a lot of better mid towers like the fractal design define s.
but if you like the h440 there is a white one you know.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
With power supply, i think the RMi series from corsair would be a good choice. i really think it will match something like the 760t, but since i am only building an atx form factor, maybe the 760t will look too big and there will be too much unused room in it for a single graphics card setup (gtx 970)?
which is primo?
a stupidly overpriced case, well the v2 is.
which is primo?
The enthoo primo, it's a full tower case with extensive water cooling support.
https://www.nzxt.com/product/detail/151-s340-mid-tower-atx-case.html S340 is probably one of the best white cases you can get
S340 in white is beautiful.
To ensure I see your reply, quote my post.
Got any questions? Send me a message.
