Setting up two d5's in serial question/s
Solved by gazabi,
1.) When I'm filling the loop, do I run the first pump first and run it through the other pump and run both of them once its "full enough"?
2a.) Will there be any downsides with flow rate in that scenario?
2b.) Will the downsides be negligible?
If your asking about wether you should run one while filling the loop, then your right. Just run one D5, the one connected to the res and it will force the liquid through the other one, no damage done.
For performance, martinsliquidlab did a great article on series vs parallel pumps, heres the link:https://martinsliquidlab.wordpress.com/2011/04/26/pump-setup-series-vs-parallel/
