Hello, I was trying to install windows 8 64 bit edition over my installation of windows 7 32 bit but it say I can only got from a 64 bit to 64 bit installation and yes I met the system requirements. What will I have to do to install the 64 bit edition? Will wiping my hard drive completely and the using the CD work?
My Rig - CPU: Intel Core 2 duo E7200 GPU: nvidia 8800gt MB: ECS 945GCT-HM (Livermore8) RAM: 2GB of some cheap crap I got off ebay CPU Cooler: Stock fan from E2140 PSU: Some thing I salvaged from my dads old pc Case: IDK Optical Drive: Compacq Drive
https://linustechtips.com/topic/43444-problem-installing-windows-8-64-bit-on-32-bit/
Formatting the HDD to NTFS and using the boot disk should work.
You can't upgrade from 32bit to 64bit you need to do a clean install or install without formatting then you will get a windows.old folder on your C:\ drive
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
You need to do a clean install. You cannot start a 64-bit setup on Windows 32-bit, because a 32-bit OS can't understand 64-bit code.
You need to boot from the Windows 8 64-bit disk (or USB flash drive) to run the setup outside of Windows.
