Key Switches
Go to solution Solved by minibois,
hey guys is theres any differences between RGB Blue / Brown with non RGB Blue / Brown switches ?
it's just a different sort of LED which instead of 1 color is able to display 16.7 million different colors.
so no.
Literally the 16.7 million color LED that is mounted in the switch.
so theres no any differences in tactical feedback and something right ? just some fancy LED added ?
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/433603-key-switches/#findComment-5811320
so no.
https://linustechtips.com/topic/433603-key-switches/#findComment-5811356
so no.
okay then thanks because theres a guy say that theres a differences between rgb and non rgb thanks :)
https://linustechtips.com/topic/433603-key-switches/#findComment-5811380
Exact same switches, just different LEDs.
https://linustechtips.com/topic/433603-key-switches/#findComment-5811461
There is a difference. It's just not a difference with how the switch feels. RGB switches have to have space for the 4 pins that the LED uses, and they also have to have space for the increased physical size of the LED. As far as feel/the way the plunger is shaped, there is no difference, so they will feel the same as any other cherry switch, but there is a difference between the two. That's why nobody made RGB switches for a long time. It simply couldn't be done.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/433603-key-switches/#findComment-5812298
