If the server supports it and you have a 100% stable connection: sure.
But you are just bound to have some times that your connection stutters or drops a bit.
https://linustechtips.com/topic/431390-download-speed/#findComment-5783848
guys i have a question
is there a way that i can have a download speed equal to may bandwith?
like for ex. if my internet speed is at 2mbps can i download at 2mbps speed also?
That's 2 (mb/s)megabits per second not 2 (MB/s)megabytes per second.
2 megabits=0.25megabytes
Also the speed depends on your connections and the servers.
https://linustechtips.com/topic/431390-download-speed/#findComment-5783851
m8 if your internet is 2Mb you need an upgrade Badly !!!
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/431390-download-speed/#findComment-5783873
i have a stable 2mbps connection but when i download files im only getting 200kbps
Is it consistent across all downloads among different websites?
https://linustechtips.com/topic/431390-download-speed/#findComment-5783886
im sorry im pertaining to 2MB/s
Your internet speed is measured or marketed as megabits and the download speeds on your computer is megabytes but if your consistently getting close to 0.25Megabytes per second download on your PC then that would be equal to the 2 Megabit internet connection you have.
https://linustechtips.com/topic/431390-download-speed/#findComment-5783921
so 2mbps or 2mBps?
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
https://linustechtips.com/topic/431390-download-speed/#findComment-5783927
Like the others have said, the 2 Mbps you get from your ISP, should be 250 KB/s when you download.
If you wanted 2 MB/s, you would need a 16 Mbps connection at the very least.
https://linustechtips.com/topic/431390-download-speed/#findComment-5784149
