It's gray.
Technically, it's supported, but the voltage may be too much.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775241
Maximum CPU TDP (Thermal Design Power) : 140Watt
I think that will support easily, dont do overclock.
8320 and 8350 have just 125W.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775266
okie...so basically just get a new mobo... problem solved.
Dont need to.. if you dont want to overclock.
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775275
okie...so basically just get a new mobo... problem solved...lol
Also...im currently using a 650ti gpu...i can get a Gigabyte GeForce GTX 760oc 2gb card for 140$ new.... what performance is there between the 2 cards?
A few fps maybe.
Would only really be worth it if you have a 1GB version of the 650 Ti
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775319
ok guys...thanks for the input...it is appreciated.
I have 600$ to update my pc.... cpu- fx6300  ... gpu- 650ti.... 12gb ram .... 500w psu... 120gb ssd.... whats my best investment for better fps for gaming?
I will be able to upgrade again next year.... another 600$ or so.... any suggestions?
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775364
R9 380 + i5 4460 + mobo
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5775429
this, and re-use your other parts...you'll find no need to upgrade again next year:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard  ($62.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($310.99 @ NCIX US)
Total: $550.93
Generated by PCPartPicker 2015-08-15 23:49 EDT-0400
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/430713-motherboard-cpu-question/#findComment-5779308
