Hey there, recently (due to it being summer break in the UK) I've started going to bed ridiculously late, like 10am Late, and waking upo at like 7pm and not seeing my family, well I can swap it back but the problem is I'm always tempted to stay up late to play with friends in America, and was wondering if anyone has a method to not do it?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/430649-sleeping-problems/
I dont go to bet quite that late, but I do get annoyed when I wake up later than 10am, as the day goes by really quick.
Since I cant really just go to be earlier, I try to wake up earlier and earlier, day by day, so even if you are tempted to stay up, you are too tired to do so.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5774529
Tell your American friends to stay up late??
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5774533
They call it a job. I used to be like you, getting up late and going to sleep late.
Even at Uni I did the same. I missed so many lectures because of this. Sleeping pills did not help because I was sidate for most of the next day and thus for morning lectures.
So now I have a job, 9:00-5:00 monday till friday. Although I can go in late if I oversleep, my boss is awesome like that but I get paid less if I do that.
I assume your age is like 14-16 so get something like a paper round or if yor age is 16-18 get a morning shift at the local asda or something. If you're at uni, theres no exuse not to get a job, what with the economy being reasonably good.
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5774660
If it's a choice, basically, go to bed earlier, simple as that, if you have turned it into a pattern that's becoming unhealthy and you can't fall sleep, try 3mg of melatonin one hour before going to bed, helps restore the circadian rhythm, it's used for jetlag for that reason. Melatonin is particularly safe, i wouldn't advice on any sedative, specially for a 15 yo.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5774701
Your problem isnt so much with sleep its with your daily, or in this case nightly, habbits.
You can either set a max limit foryour self for how long you will stay up, lets say midnight at the most, and if you can stick to that then you will be fine.
If you tend to ignore your self imposed max limits then i would say only game with your friends on certain nights.  Friday sat and Sunday can be your gaming nights, but the rest of the week stay away from the games.  If you remove yourself from the problem then the symptoms of that problem should disappear.
I've had similiar issues.  I would sit on the couch and watch netflix/youtube well into the night and not get anything done.  I found myself turning on the TV the moment i walked in the door.  Now i try avoid turning on the TV until after a set time.  That way i get more stuff done and dont feel like ive wasted an entire evening.
Hope some of what i said helps.
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5774951
Pretty sure that would make it worse, since the op is in england...
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5776689
damn and it thought i went to bed late (6:00) and i wake up at about 15:00 xD
OP dont worry, thats normal with gamers, me personally i only go to bed because i dont live alone and it would be akward to stay up all night xD
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/430649-sleeping-problems/#findComment-5777869
