So I've never owned an LED IPS monitor. I'm getting one and I'd like to know how you are able to spot dead or stuck pixels? Is it like a little black dot or what? Also how are you suppose to even check for one? The screen changes so fast I'd never be able to tell if it was a dead pixel or just a dark image. Finally what is backlight bleed? I keep finding different answers and can't find one consistent one.
https://linustechtips.com/topic/428625-ips-pixel-help/
Look up dead pixel test, but basically display a full screen black, white, red, green and blue images. If any pixels are not the same, that means they are stuck/dead. If you are buying a NEW IPS monitor from a reputable brand, you SHOULD NOT have any dead pixels.
As far as backlight bleed, that refers to the edges being slightly darker than the rest on a very dark/fully black image.
When in doubt, re-format.
https://linustechtips.com/topic/428625-ips-pixel-help/#findComment-5749523
You're likely witnessing IPS glow, not backlight bleed.
https://linustechtips.com/topic/428625-ips-pixel-help/#findComment-5749548
I ask cause I'm thinking of getting the XB270HU and I've heard they have QC issues with dead pixels and backlight bleed.
https://linustechtips.com/topic/428625-ips-pixel-help/#findComment-5749563
Dead pixels are usually just black, while stuck pixels will be one of a bunch of bright colors. You could also have a dead sub pixel (like one of the colors in the rgb matrix), which can be a bit harder to spot, as the pixels will respond normally, but just with one dead subpixel.
There are many sites on the internet that will go though a munch of colors, to make it easier to spot any kind of pixel anomoly.
Back light bleed is generally a part of the screen where the backlight "bleeds" through more than it should, usually characterized by a bright spot on a dark background. It generally occurs around the edges.
http://cdn.overclock.net/1/12/12288d98_p1000082pv.jpeg
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/428625-ips-pixel-help/#findComment-5749609
