Hey, I'm new to overclocking and I got the new 6600k. I am currently at 4.5ghz at 1.285v, if my temps are at 55 degrees c (using AIDA64?) is it ok to keep going higher by increasing the voltage? Also whats the max safe voltage to use for skylake? I found this guide and it says 1.45v if your on a waterloop: https://drive.google.com/file/d/0Bz2VRRbLPrZnMXBnOXRWeVlHcHM/view?pli=1 , apparently its by ASUS
Thanks
https://linustechtips.com/topic/428578-skylake-overclocking-help/
If it's stable without increasing voltage, then see how far you can go. If it's stable now, you can try reducing the voltage as far as you can before it becomes unstable. I'm not too familiar with Skylake, but I wouldn't go far over 1.3-1.35v
thats actually quite good and yes voltages will affect temps, as with voltage I would max it out at 1.3v.
