so i was do my thing then my graphics card processor exploded (didn't have a heat sink on at the time) i was wondering if any one new how to fix it? :P
Update: im just trollin i ripped it of with some metal and burnt it with a lighter but i was wondering if you could fix it i thaught unlikely or impossible xD
post-230279-0-07843700-1439396694_thumb.
https://linustechtips.com/topic/428551-how-do-i-fix-an-exploded-graphics-processor/
You can't fix this.
That's the main (and most expensive) part of the graphics card, so just buy a new one.
Anyway, it's definetely not a good idea to use a graphics card without a heatsink.
Your warranty should be voided if you removed the heatsink.
i7 6700k - 32GB DDR4-2133 - GTX 980
How do you fix it? You don't...
My Build: i7-4790K, 212 Evo, Asus Maximus VI Extreme, Crucial Ballistix Sport 16GB DDR3-1600, Intel 730 240GB SSD, WD Blue 1TB, EVGA GTX 980Ti ACX 2.0, NZXT H440 Blue/Black, EVGA 650W 80+Gold.
Most of the time, it's not the computer, it's the person using it.
troll? that looks like it was smashed with a hammer
Nah it looks like a delidded CPU thats been hit with a blowtorch
Gaming PC: CPU: i7 4770k@4.2GHz w/ CM Nepton 140xl, GPU: Gigabyte 1070 @2050, RAM: ADATA XPG V1 16GB@2133MHz, Mobo: MSI Z97 Gaming 7, Case: Corsair NZXT S340.
Buy a new one. .
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
You don't ;)
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
No, you can't fix a GPU that is fucked. The silicon is useless and according to your photo, it's obviously completely unfixable.
Okay here's what you do: Get  a decent size tube of thermal paste. This will help with heat output and work a bit like glue.
Apply Thermal paste to the backside of the gpu chip itself.
Apply the gpu chip to the pcb in it's original position.
Apply thermal paste to the heatsink.
Apply the heatsink to the top of the gpu/ pcb combo.
Let sit for at least two hours, or until you can shake it and nothing falls off. Should something fall off, see above steps.
Apply the gpu to the trash can.
Do your favorite victory dance.
only if that was a GPU, that core die is too small I place my bet on mobile core2duo or any dual core laptop cpu.
it is a gpu
show us the other side of it
