Help choosing a new z170 motherboard
Solved by NumLock21,
Go for the most expensive. Why? It's a gift.
Seriously, between the 3, Krait is out unless you want to run a single gpu. with 2 gpus, it will block off the SATA ports. The Hero has red accents, so it might not fit your color theme, the logo I believe is RGB, unless you want to go with a triple color theme build of red/black/white. Deluxe is probably the one that fits your color them the most of black/white, it also has more features out of the 2 boards like dual gigabit lan, 3x3 wifi/bt, up to total of 10 fan connectors (with fan extension card), 16 phase vrm, and deluxe socket where it has extra pins. The Deluxe also has RGB lighting
