Just wondering which setting was best to test my cpu (3570k) for temperatures.
I'm running it at stock and I just want to know my current max temps as reference for when I overclock.
Do I test with large FTTs for maximum heat, blend or is there a optimized custom setting?
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
https://linustechtips.com/topic/4248-prime-95-settings-for-cpu-temperature-tests/
One instance of blend, and one instance of small fft.
Yea agreed for 24 hours if you overclock to make sure its 100% stable.
Be sure to also monitor your temps with real temp to make sure your cpu won't overheat
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
